Blower fan and resistors
I am going to replace my blower fan. I am also going to replace the blower fan relay and the ac blower transistor and resistor for the ac. Do i have everything covered. It all wrks fine but being a 2000 i just want to replace everything to knew. Does anyone know wear the relay is located. I know wear the fan and the ac transistor are. Thank you again for all the help. Joe.
I found a 99 D2 uses a different blower vs later models (not sure about a 2000 model). I compared it to the later models and the real difference is the price & the plug itself. The aftermarket unit for a 99 on Rock Auto was like 37.00. You could just cut off the pig tail from the later style and cut off the little harness on the aftermarket 37.00 and use two butt connectors vs spending around 50.00 for the later unit.
Yep Relay #4
Yep Relay #4
chermecz
08-09-2012 10:02 PM
