Blower fan and resistors
Old May 11, 2018 | 11:17 AM
lndrover@carolina.rr.com's Avatar
Default Blower fan and resistors
I am going to replace my blower fan. I am also going to replace the blower fan relay and the ac blower transistor and resistor for the ac. Do i have everything covered. It all wrks fine but being a 2000 i just want to replace everything to knew. Does anyone know wear the relay is located. I know wear the fan and the ac transistor are. Thank you again for all the help. Joe.
Old May 11, 2018 | 11:33 AM
JUKE179r's Avatar
The blower relay is #4 in the engine bay fuse box.
Old May 11, 2018 | 01:22 PM
Best4x4's Avatar
I found a 99 D2 uses a different blower vs later models (not sure about a 2000 model). I compared it to the later models and the real difference is the price & the plug itself. The aftermarket unit for a 99 on Rock Auto was like 37.00. You could just cut off the pig tail from the later style and cut off the little harness on the aftermarket 37.00 and use two butt connectors vs spending around 50.00 for the later unit.
Yep Relay #4
vonrock
Jan 4, 2016 05:55 PM
chermecz
Aug 9, 2012 10:02 PM
remember5
Jan 13, 2011 09:33 PM
sdsilvere38
Sep 16, 2008 08:42 AM
ajh
Sep 21, 2007 11:34 AM
