blower motor issues
Old Feb 19, 2016 | 06:44 PM
me 2's Avatar
Default blower motor issues
My AC turns on but no air is blowing out. I have replaced both relays, blower motor and resistor still no air is blowing out. Any ideas?
Old Feb 19, 2016 | 08:58 PM
Alex_M's Avatar
Have you tried directly connecting the blower motor to a car battery to see if it spins?
It is possible the motor is dead also. If that's the case then there is a great mod (Charlie_V has done it) where you retrofit a Pontiac blower motor. They're pretty cheap new and move a lot more air.
If you've got a multi meter then you could test the connections to see if it's getting power.
Old Feb 20, 2016 | 06:03 AM
Daedrix's Avatar
Banned
I've done that mod and its a great improvement.
Old Feb 20, 2016 | 07:38 AM
me 2's Avatar
Default Stuff
Which connector are you referring to?
Old Feb 20, 2016 | 08:09 AM
Daedrix's Avatar
Banned
I think he means the blue on next to the blower it self.
Old Feb 20, 2016 | 09:14 AM
mark d's Avatar
There are two connectors. I replaced my blower motor because it was going on and off at odd times (had power when I tested with a meter and the motor spun when I hook it up direct so I figured it was the motor brushes). Then I found out it was a fried connector a few inches away from the first connector.
Old Feb 27, 2016 | 08:55 PM
me 2's Avatar
Default stuff
So I tested the blower motor and it works but I noticed that there was only one relay that clicks. Should both relays click or should there be no clicking at all.
Old Feb 27, 2016 | 11:14 PM
number9's Avatar
How & where are you applying pwr?
File Type: pdf
Old Feb 29, 2016 | 11:03 PM
LR03NJ's Avatar
In my case. I had a loose wire near the blower motor. Its a thick blue wire which gets fried all the time. Need to reconnect with heavy duty crimp connector. That wire gets really hot when loose.
Old Mar 1, 2016 | 07:33 AM
me 2's Avatar
Yeah, checked the wires plus I added a different harness with the newer relays.
vonrock
Jan 4, 2016 05:55 PM
mherson
Oct 17, 2010 04:05 PM
nelbra
Mar 21, 2010 03:30 PM
SDinDS
Feb 16, 2009 06:53 PM
eric2
May 28, 2005 02:44 AM
