..:: The blower situation ::..
Old Nov 2, 2016 | 07:11 AM
adolfojbonilla's Avatar
Hi All!
Happy to report that second maintenance attempt was a success.
Blower have been working just fine since Sunday, and no noise.
I do think it might not be running up to speed, but that might be a perception issue, actually don't recall how strong it blew when I bought it, or haven't been able to compare it to a similar truck, meanwhile I'm happy, besides #WinterIsComing.
Those instructions are on point, although no good explanation is given on how to get the Squirrel Cage out -I used a screwdriver and a hammer; and firmly, but gently, delivered a tap on the shaft until it slid out, you could see the dirt that came out during the hammering process.
Sprayed a new can of Electronic Cleaner in there, but couldn't find the 3-IN-ONE for motor applications, so ended up buying the regular one.
Thanks all and good luck to those attempting the Blower Revival! ;-]#
Old Nov 2, 2016 | 05:49 PM
JUKE179r's Avatar
I use Lucas semi-synthetic assembly lube which is a thicker motor oil that I use for electronic motors. I use this constantly on client's Technics 1200/1210 turntable motors that I modify in my spare time.
#WinterIsComing
#GOT
Old Dec 17, 2016 | 05:02 PM
Hello Roverers!
In the past couple weeks I've been noticing the blower revving up or down, and at max speed -supposedly- it sounds and feel like it is not blowing strong enough.
If you read this post, you'll know I took it apart and did an already known maintenance to it, since then not squeaky noises and turns on and off on point; I just don't feel is blowing hard enough, and also the revving issue, so any ideas where to look? besides the "time for a new blower" recommendation? thanks!
vonrock
Jan 4, 2016 05:55 PM
tweakrover
Feb 17, 2010 12:11 PM
flattrakker
Jan 15, 2008 06:11 PM
RovingRiesensCubed
Jan 12, 2008 01:11 PM
DiscoDiva
Jan 29, 2007 08:00 PM
