Bolt specs for rear spring mounts?
Old Mar 14, 2015 | 12:49 PM
ralphobell's Avatar
The actual heating element could have an issue. Also make sure they are plugged in under the seat. Have you tried both sides?
Old Mar 14, 2015 | 01:45 PM
Alex_M's Avatar
Yep, tried both sides and neither worked. It's plugged in atleast on the drivers side. I didn't check the passengers side. Is there a fuse for the heated seats? I checked the ones under the seat, but I haven't looked in either fuse box.
Old Mar 14, 2015 | 02:12 PM
ralphobell's Avatar
Did you check the Relay under the seat. should be yellow. It is for the heated seats.
Old Mar 14, 2015 | 03:01 PM
Alex_M's Avatar
I didn't. I'll be home after while and I keep a number of extra relays around, so I'll check then.
Old Mar 14, 2015 | 07:30 PM
Alex_M's Avatar
Ok, I checked the relay. I replaced it twice just to be safe and still nothing. Any more ideas?
I did see this plug (http://imgur.com/vdAIZ5M) under the seat. I don't see it's mate anywhere. Should it be connected to something?
Old Mar 14, 2015 | 08:09 PM
Alex_M's Avatar
Ok, so I just went and looked under the leather seats. They have the same plug, but something is hooked into them and the wires run up into the seat, I'm assuming that's the element. I'll open up the upholstery and see if I can just switch the elements from the leather seats to mine instead of switching the whole seat. Hopefully tomorrow, maybe next week end. I'll update then.
Edit: I'll be making a new thread and copying all the info from here for any future readers looking to find this information since the title would be misleading.
Old Mar 15, 2015 | 08:05 AM
ralphobell's Avatar
The elements are glued to the cushion. They can be removed but you need to be careful doing so. To be honest and to save you the headache of trying to put the cushion back in place. I would just change out the seats.
Old Mar 15, 2015 | 08:14 AM
dusty1's Avatar
You can change the title. Just edit and go advanced.
Let me know what you want. I will change it, if you can't figure it out
DaveWinCO
Nov 10, 2014 08:52 AM
FlyingZebra34
Jul 6, 2013 04:07 AM
NiteTrain
Sep 10, 2010 08:48 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
Mark G
Nov 11, 2007 09:50 AM
