Bosch engine clicking
Old Jul 7, 2018 | 03:48 PM
EAustin494's Avatar
Default Bosch engine clicking
I know this gets discussed a lot but I have an 03 disco the when cold runs nice and quiet but as soon as it comes up to temp it clicks. I pulled the plugs all were dirty and shot. I checked the cyls with a bore scope but found normal filth, no steam cleaning. I assumed it was bad lifters since it sat a lot before I bought it so 11 hours of tear down and reassembling same issues persist. I do not have any dash lights and if you put a stick against the motor to listen to it it still sounds like lifters. Could it be a bad oil pump? Should I put a pressure gauge on it? PO said it has been doing it for about 5 years and has not gotten better or worse. Thank you in advance for help. As I tore the motor down I did not find anything I would not expect to find in a truck with 192K miles on it.
Thanks Eric
Old Jul 7, 2018 | 11:36 PM
User's Avatar
It kind of sounds what my 2002 does with 230k~ miles. When cold, nice and quiet, but when warm the engine kind of sounds like a bad catalytic converter. Interestingly idle oil pressure is about 12PSI which I believe is fairly "okay".
I run 20w50 for summer, and 10w30 in winter. No change. It's been doing it since I've owned the truck since I think 2010.
Best thing to do is put a gauge on and do a certain check, the oil pump is a common issue item. I plan to do mine soon as I found a new set of timing chain and gears in my garage so why not.
Old Jul 8, 2018 | 08:34 AM
EAustin494's Avatar
i found a thread from 2015 that said the oil passages in the rocker arms clog up and can cause it. I am going to try taking mine apart today and cleaning them to see it that works. I am positive they are dirty. I will let you know if it works.
Old Jul 8, 2018 | 10:13 AM
mr. choodles's Avatar
It is your rockers. I had the same thing. Interestingly enough, a drive cross country solved the issue. Now I do Rotella 15W-40 with 1 quart of Lucas stabilizer + a large filter every 2K. Purrs like a kitten.
Old Jul 8, 2018 | 05:53 PM
shanechevelle's Avatar
Lack of clean oil causes the shellac to build up and fill in the holes.
Not always the case....but definitely worth a cleaning.
Old Jul 8, 2018 | 07:40 PM
EAustin494's Avatar
I tore the drivers side apart today and 5 or the rockers were clogged solid and the others had some clogging. I just realized today that when the oil was changed they put 5-30 in it and that seems way to thin. I will take the passenger side apart and clean those and put the heavier oil in it with some Lucas and see if it helps. Thank you everyone.
Old Jul 8, 2018 | 10:24 PM
Dave03S's Avatar
Rotella 15w40 is your best friend... $12.99 per gallon at Walmart. All the ZDDP and detergents you need to keep those clean.
Old Jul 9, 2018 | 07:59 AM
Good to know and thank you for the update. 5 quarts of Rotella and 1.1 quart of Lucas Oil Stabilizer does it for me.
EAustin494
Sep 11, 2018 07:40 PM
nickm347
May 8, 2018 02:38 PM
Conner Clancy
Apr 11, 2018 04:16 PM
giftshopduane
May 10, 2012 12:39 AM
racingwoody
Nov 28, 2010 11:37 AM
