Brake calipers Disco I to Disco II
Old Jun 26, 2013 | 01:41 AM
msn619's Avatar
Default Brake calipers Disco I to Disco II
I searched this on the forum but no luck maybe long time members can help me, I was at the ecology pick n pull and found a disco I with a nice 4 piston calipers (I didn't know they came with 4 piston calipers) my questions are
1. is the 4 piston calipers from a discovery I better than the 2 pistons of the discovery 2?
2. will the calipers fit on the discovery 2 with just install & go with out modifications?
here are the calipers
Old Jun 26, 2013 | 07:23 AM
ukwildcats's Avatar
Not an expert but I checked Advance Auto online -- the front caliper's do not share the same part number for replacement calibers. Seperate part number for Front Left D1 from Front Left D2.
Take that information for what it is worth -- maybe they will work.
UK
Old Jun 26, 2013 | 07:24 AM
antichrist's Avatar
Discovery 1's didn't come with four piston calipers, it must have been a retrofit.
D1 and DII calipers are different.
Old Jun 26, 2013 | 07:57 AM
drowssap's Avatar
they are probably off a range rover, my 90 with abs has 4 postion calipers
Old Jun 26, 2013 | 08:51 AM
Dan7's Avatar
Obvious follow-up question...are there RR calipers that are both better than the stock DII and direct bolt on? If so, what year/part #/etc?
Old Jun 26, 2013 | 10:14 AM
jafir's Avatar
They didn't?
Old Jun 26, 2013 | 11:42 AM
antichrist's Avatar
Originally Posted by jafir
They didn't?
sorry, was thinking rears.
Old Jun 26, 2013 | 08:01 PM
msn619's Avatar
yeah anyone did this to a Disco 2 yet?
Old Jun 26, 2013 | 09:18 PM
If you want better brakes on a D2, replace all 6 rubber brake hoses, installed slotted and drilled rotors and Akebono ceramic pads, you will be surprised at the difference
Old Jun 26, 2013 | 10:44 PM
msn619's Avatar
right now I have a steel brake lines on all 6, bosch quietcast rotors all 4 and a powerstop Z16 evolution on the front & centic on rears I don't know if its the ceramic or just the semi metallic didn't change the rears they are still about 50% when I got the disco 2. the brakes are ok the feel is good it stops ok but if I can improve more the better right.
toofaroffroad
Apr 7, 2013 10:27 AM
Sam95disco
Feb 19, 2013 08:19 AM
Cassidy Bodle
Jun 3, 2012 11:17 AM
calebbo
Jun 30, 2011 01:34 PM
welling4x4
Sep 29, 2010 11:10 AM
