brake fluid mythbuster
Old Nov 7, 2006 | 08:48 AM
chrisusvi's Avatar
Default brake fluid mythbuster
I have a 97 Discovery and my parts supplier tells me that the ONLY brake fluid to use is this special brand Castrol GT/LMA Dot 4 brake fluid. The sales guy tells me that other brands don't have the protection that Castrol has and other brands would break down the seals quicker. Is this a myth or are there other brands that will work just as well. Are there other brands that works just as good as long as the brake fluid is a Dot 4?
Thanks.
chrisusvi
Old Nov 7, 2006 | 10:32 AM
Default RE: brake fluid mythbuster
All DOT 4 brake fluids are pretty much made to the same standards set by the manufactures, with the exception of of a few out there that make a pure synthetic brake fluid like Vavolines synthetic brake fluid.
The word for you parts guy is "BUSTED".
Mike
Old Nov 7, 2006 | 01:42 PM
chrisusvi's Avatar
Hi Disco Mike,
A quick note about the synthetic brake fluid. In your opinion, do you think that synthetic Dot 4 brake fluid be good enough without messing up the seals...as the sales person claims would happen.
thanks.
chrisusvi
Old Nov 7, 2006 | 01:44 PM
chrisusvi's Avatar
Hi Disco Mike,
thanks.
chrisusvi
Old Nov 7, 2006 | 03:08 PM
I have been running it for nearly 4 years because of the heat generated by my DBA rotors and kevlar pads, works great with no brake fade,
Mike
Old Nov 12, 2006 | 07:30 PM
Landzu's Avatar
ORIGINAL: chrisusvi
Thanks.
chrisusvi
Atlantic British Ltd. has said the same thing about using only the Castrol brake fluid.
http://www.roverparts.com/Parts/2521.cfm
This maybe a Disco I thing.
I use the Castrol brake fluid.
Old Nov 13, 2006 | 11:19 AM
DiscoJag's Avatar
Hi folks. This may sounds like a dumb question, but I've been (mistakenly) putting DOT 3 brake fluid in my '96 Disco I for a while. Is it okay to suck out what I can, bleed and put in DOT 4 ? Will they mix alright, or do I need to flush the whole system ?
Thanks,
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
flyingalexf68
May 9, 2006 01:51 PM
