Brake Lights in my 2000 Disco
Old Dec 14, 2006 | 06:53 PM
Benhamtroll's Avatar
Default Brake Lights in my 2000 Disco
Okay, this is a new one to me. My brake lights are out in my 2000 Disco. I checked the fuses, which are fine. Does anyone have an idea of what to check next? I had a brake problem about a month ago, where I lost a caliper bolt in the right front. I had a brake shop fix it. Is it possible that that could have screwed it up, or am I looking at the joys of electrical issues?
On a related note, my cruise control is not functioning either.
Old Dec 14, 2006 | 07:32 PM
Default RE: Brake Lights in my 2000 Disco
Have you checked the brake switch at the brake pedal to make sure there is voltage there when the brakes are applied?
Are all 3 brake lights not working?
Mike
Old Dec 14, 2006 | 07:43 PM
Yes, all three lights are out. I haven't checked the switch. That's actually something I've NEVER done, in any vehicle I've ever owned. What am I looking for, and how should I check it?
Old Dec 15, 2006 | 11:44 AM
Look up where the brake pedal anchors, there will be 2 small switchs, it is common for the brake switch to fail, they are inexpenseive and easy to replace.
Usually when the switch fails, you have a hard time shifting the tranny also, but in your case, if you use a test probe on the switch I bet you will find it is failing.
Mike
Old Dec 15, 2006 | 11:57 AM
Thanks, Mike. I certainly hope it's this. $20 is much easier to stomach than someone haing to troubleshoot my electrical system. . . ;-) Fortunately, the 2000s still had decent wiriing harnesses.
discodorothy
Sep 9, 2021 11:15 AM
USMC_Denver
May 8, 2009 12:41 PM
DiscoverAU
Jul 10, 2008 09:24 PM
klh113
Dec 17, 2007 02:13 PM
