brake lights stay on....
Old Jun 3, 2014 | 11:12 AM
Zednanre's Avatar
4th Gear
Default brake lights stay on....
Again, hello to everyone...
As soon as I insert my key into the ignition, the brake lights on my1999 disco 2 go on and stay on forever, until I take my key out.
Well, I was able to fix the problem without spending a dime.
There is a pin that can be pushed in and out at the tip of the brake light switch. The one for my car is a little longer than the one that was in it. Because of the fact that I am in a third world country I had to improvise. I drilled a little hole on top of the pin and screwd a half inch screw half way, that extends it to the length that was required, put it back on and voila... Woks as a charm... So, make sure you have the right one in place. I hope I was able to help somebody today.
Old Jun 3, 2014 | 04:40 PM
Great work around! Which small country?
Old Jun 4, 2014 | 12:46 AM
jimvw57's Avatar
I would suggest you get a switch on order. Mine started out like that and then quit working soon afterwards. Without the brakelight switch, I was unable to shift out of park. (brakes had to be applied before shift would move)
Old Jun 4, 2014 | 09:53 AM
Zednanre's Avatar
4th Gear
Thanks for the advise. I will plxa the other very soon. Thanks again...
Old Jun 4, 2014 | 07:38 PM
jfall's Avatar
Change the switch with the truck off.
Or else you may get a fault and a code.
lost in france
Defender
May 24, 2015 08:49 AM
funkymunk
Dec 11, 2008 08:36 AM
FJL
Jan 11, 2008 01:12 PM
beardbw
Aug 29, 2006 10:41 AM
buddy
May 26, 2006 12:35 PM
