Brake Pad questions... Akebono
Old Feb 11, 2011 | 01:19 PM
jhewitt1111's Avatar
Default Brake Pad questions... Akebono
I ordered my pads from advanced auto. I got two sets of pads, Eur676 front, Eur493 back. I have not yet done the brakes on this beast before so it is new to me. I was a little concearned about the size of the Eur493. I have read in the forums that these are correct, but I just wanted to make sure. Thanks in advance.
Old Feb 11, 2011 | 01:28 PM
Bundu's Avatar
Banned
Those are the correct rear ones.
Have you done the brakes before?
How are your rotors?
Old Feb 11, 2011 | 02:36 PM
texmbr's Avatar
Those are correct as Bundu stated. Easy job. I just did new drilled slotted rotors and Akebono's on my 02, with a full flush and bleed. What a difference. I now have a great pedal. Found a leaking seal left rear in the process and fixed it the next weekend. Get a caliber piston tool at Autozone (cheap) and make sure your pistons are all the way in before re-assembly.
Old Feb 11, 2011 | 02:37 PM
I have done them on my jeeps and tacoma. From what I understand these are easier. My dad loves projects like this so he will be helping me. Plus he has the garage and tools. Rotors look good feel smooth with a tiny lip. Ill check them once the tires are off. I have checked ahead to make sure they are in stock if needed. Any other advice or things I should look for and do while I am in the project?
Old Feb 11, 2011 | 02:38 PM
Will do. I was planning on a flush and bleed. I have referbished set of calipers I picked up just in case. Figure I'll need them someday and it was a steal of a price.
Old Feb 11, 2011 | 02:40 PM
Bundu's Avatar
Banned
It's an easy job. I use a G clamp to push back the brake calipers, I also bleed the brake fluid out when I push the calipers back instead of pushing that back into the reservoir.
Old Feb 11, 2011 | 06:12 PM
FightOnUSC79's Avatar
Just did Akebono from and rear with new LR Rotors. You will not be disappointed. I was told by a few people not to do drilled and or slotted as they destroy the pads at a faster rate. So be careful with that.
Old Feb 12, 2011 | 07:44 AM
BackInA88's Avatar
I have Akebono and drilled rotors (got them dirt cheap of eBay around $160 for all 4 shipped, although I see no need for drilled or slotted on a DII) front and rear with over 60K on them and they still have plenty of pad left.
Forester
LR2
16
Mar 4, 2015 08:55 AM
acamato
Jul 11, 2013 01:23 PM
archaeology_student
Mar 14, 2013 11:53 PM
TRIARII
Dec 1, 2012 11:46 AM
jhewitt1111
Feb 22, 2011 07:16 AM
