Brake Pads & Traction Control
You may be right, im not sure which crappy brand of pads the previous owner had on it but they did have a higher bite. I know metallics generally have a higher bite than ceramics, just wondering if that would make a difference or does the tc use a higher or lower pressure to stop the free spinning wheel? Or was the tc setup to use the factory pads?
What I'm trying to say is the pads really aren't what you're feeling. The rest of the braking system is causing the soft feeling not the pads. This is the case every disco regardless of the brake/rotor combo. You can stiffen it up a bit with stainless lines but even the most aggressive pad on Earth will feel a little soft on the first press in a disco.
I put a set of Akebono pads and EBC dimpled rotors on my 2004 Disco and the difference was night and day. The pads took a little while to brake in (haha) but after a month or two they felt great. I really noticed a difference on slow steep descents off road, they bite but have a true feel to them with noticeably more control and confidence.The nicest thing with these akebono pads is I can go weeks without having to wash my wheels - almost zero brake dust!
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
