Rear hub replacement/Tool
Old Dec 14, 2013 | 11:35 PM
LADEROUTE's Avatar
Default Rear hub replacement/Tool
Has anyone managed to swap a rear hub on a D2 with the use of non pneumatic tools?
Is there a special Land Rover only tool or will a standard puller suffice?
Any tips on how to get these buggers off would be appreciated.
Thank you in advance.
Old Dec 15, 2013 | 08:07 AM
rovertech1's Avatar
Once you get the big center nut off and the four 15mm head bolts out that hold the hub to the axle housing, you can use a generic (heavy duty) puller to remove the hub. The axle will bottom out inside the differential as its pushed through the hub. Once it bottoms out, the hub will start to slide out of the axle tube. This could all be made much more difficult if the truck is rusty...use lots of penetrating oil!
Old Dec 20, 2013 | 06:07 PM
LADEROUTE's Avatar
Great info - Thank you.
As for getting it back on, get the hub in place and rubber mallet it on?until I can set the nut and then crank it down to the specified torque#?
Old Dec 21, 2013 | 09:00 AM
04duxlr's Avatar
That's what I did. I cleaned everything up and oiled the o-ring then used a dead-blow hammer to get it close. Then I pulled it in the rest of the way with the bolts.
Make sure you pick up some retaining compound for the splines! Not a threadlocker, but the retaining stuff for bearings on shafts, etc. You need to seal them so it won't leak gear oil and also to fill any spaces between the shaft splines and the hub so there is no movement. I used Loctite 609 on the advice of the manufacturer. The 609 lets you take the pieces apart without heat.
Old Dec 29, 2013 | 07:22 PM
LADEROUTE's Avatar
Thanks for the help all. I'll report back when I give it a try.
Oasisplayer311
Aug 12, 2015 10:43 PM
Colorado David
Jul 21, 2014 03:19 PM
0304Disco
Oct 17, 2012 04:11 PM
mattyh007
Sep 17, 2009 02:07 PM
01 Discovery
Dec 1, 2006 12:07 AM
