Brake Pads & Traction Control
Old Dec 25, 2013 | 09:20 PM
lmcgrew79's Avatar
Default Brake Pads & Traction Control
I recently switched to akebono pads about a month ago and they dont have a very aggressive initial bite. I was wondering what effect if any this has on the traction control system. Would a pad with a higher initial make the tc perform better off road?
Old Dec 25, 2013 | 09:29 PM
br0keit's Avatar
I think you're confusing the "disco two step" with a lack of initial bite. The akebono pads certainly bite fine and are very fade resistant but the disco has a known soft first pedal press. Pump your brakes and the second press will stop MUCH more aggressively.
Old Dec 25, 2013 | 09:39 PM
lmcgrew79's Avatar
You may be right, im not sure which crappy brand of pads the previous owner had on it but they did have a higher bite. I know metallics generally have a higher bite than ceramics, just wondering if that would make a difference or does the tc use a higher or lower pressure to stop the free spinning wheel? Or was the tc setup to use the factory pads?
Old Dec 25, 2013 | 10:19 PM
br0keit's Avatar
What I'm trying to say is the pads really aren't what you're feeling. The rest of the braking system is causing the soft feeling not the pads. This is the case every disco regardless of the brake/rotor combo. You can stiffen it up a bit with stainless lines but even the most aggressive pad on Earth will feel a little soft on the first press in a disco.
Old Dec 27, 2013 | 08:32 AM
drowssap's Avatar
I only way I was able to get rid of the "disco two step" was to replace my lines and completely flush the system.
Old Dec 27, 2013 | 01:20 PM
lmcgrew79's Avatar
Short of the brakes being needing bleed, what your refering to is called knockback. That isnt what im talking about, im talking about the compound of the pads. Some pads have a higher bite than other pads, and i was wondering if the tc system is set up to work with factory pad compound, or is it set to work off of pressure?
Old Dec 29, 2013 | 07:05 PM
LADEROUTE's Avatar
I put a set of Akebono pads and EBC dimpled rotors on my 2004 Disco and the difference was night and day. The pads took a little while to brake in (haha) but after a month or two they felt great. I really noticed a difference on slow steep descents off road, they bite but have a true feel to them with noticeably more control and confidence.The nicest thing with these akebono pads is I can go weeks without having to wash my wheels - almost zero brake dust!
wolfgang528
Defender
Dec 28, 2010 04:25 PM
gamecockdisco
Jul 12, 2010 08:34 AM
Disco2Fever
May 16, 2010 10:10 AM
ljdiscovery
Jan 17, 2009 01:35 PM
rodrick smith
Apr 13, 2007 06:09 PM
