Brake pedal soft...
Old May 8, 2007 | 11:19 AM
reconram's Avatar
6th Gear
Default Brake pedal soft...
My wife has a 2000 Discovery and the brake pedal is soft. When you first mash it, the pedal travels a little far, still stops but I'm a litlle concerned. If you pump it one time it holds good. Could the master cylinder be leaking through the bypass line?
Thanks for all the info in advance.
Reconram
Semper Fi
USMC 1988 - 1998
1st Force Recon Bn.
Old May 8, 2007 | 11:50 AM
Elhoff's Avatar
Default RE: Brake pedal soft...
My 99 D2 has always been like this also. I always assumed that it was just expansion of the rubber brake line sections. I am very interested in what others have to say on this.
Elliot
Old May 8, 2007 | 12:14 PM
How many miles on your wifes truck, when was the last time you replaced all the brake fluid?
Mike
Old May 8, 2007 | 12:16 PM
ORIGINAL: Elhoff
Elliot
Replacing he rubber hoses and using the new stainless lines makes a nice difference along with a full brake flush. I did this about 4 years ago with my 99 with no issues since.
Mike
Old May 8, 2007 | 12:43 PM
reconram's Avatar
6th Gear
Mike,
It has 100,500 miles on it. We got it with about 90,000 on it. I haven't changed it so it's hard telling. Try changing it first?
Reconram
Semper Fi
USMC 1988 - 1998
1st Force Recon Bn.
Old May 8, 2007 | 03:12 PM
Yes, go buy 2 qts. of brake fluid and do a complete flush. Then if you want more stopping power replace the lines.
Mike
Old May 8, 2007 | 03:26 PM
StevenDiscoII's Avatar
And make sure there is absolutely no air left in the system lines anywhere.[sm=smiley23.gif]
Old May 8, 2007 | 06:11 PM
reconram's Avatar
6th Gear
Will do, Thanks guys for all the help.
Reconram
Old May 9, 2007 | 08:43 AM
Aquaholic's Avatar
I had the same problem in my 03 SE with 40,000 miles. I replaced the fluid then bled the system twice.
stb616
Sep 19, 2014 06:10 AM
binvanna
Oct 30, 2012 12:07 PM
hotdogpimp
Apr 27, 2009 12:21 PM
m1964
LR2
Nov 17, 2008 09:49 PM
jwmstang
Apr 12, 2007 03:46 PM
