Brake pedal is soft or travel seems too long
Old May 23, 2016 | 09:44 PM
  #21
BS50MGSXR's Avatar
well got a 10ft extension off ebay and now i can move the nanocom to each wheel well with me. does the hawkeye walk you threw the brake bleed procedure? if so, can you tell me what it is so i can try and follow it with my nanocom?
Originally Posted by drowssap
Have never checked the length but I do have to run it out the back door in order to reach.
Old Jun 12, 2016 | 11:24 AM
  #22
bcolins's Avatar
Default Problem found,...another vacuum leak at intake manifold
Turned out to be the cap on the small vacuum test port on the intake had a large hole in it. Fixed it,....and now my idle speed has returned to normal as well. Win for the home team!
Old Jun 13, 2016 | 12:36 AM
  #23
Manbeer's Avatar
Also, it has nothing to do with the pedal feel but always clean rotors before installing as they come coated in oil to protect them from rusting, not that much engine and tranny won't give them it's own coat of oil before long anyway
RandyH1221GJ
Nov 10, 2019 05:34 PM
rice0086
May 9, 2011 09:00 AM
elrocha69
Dec 14, 2007 05:42 PM
turpin
Jun 6, 2007 10:24 AM
jwmstang
Apr 12, 2007 03:46 PM
