brake problem
Old Oct 15, 2008 | 10:22 PM
rsm688's Avatar
Default brake problem
[hr]
Well on the disco I just got the brakes are acting funny. The anti-lock brake light is on and when I am braking some of the times it makes this weird noise that sounds like it is coming from in front of the drivers side and it feels like the driver side front brake either locks or unlocks and the braking feels a little different right after. Any ides? Also it sounds like a popping noise in the suspension in the same side of the vehicle.Thanks,spencer[/align]
Old Oct 15, 2008 | 10:41 PM
tacomatech's Avatar
Default RE: brake problem
Have the faults checked and then go from there.
Old Oct 16, 2008 | 11:01 AM
D1 or D2, how many miles on it?
Old Oct 16, 2008 | 04:54 PM
Ok, since you have a DI pull the fuse to the ABS, the light will stay on but the brakes will work like normal non-ABS brakes. No more noise, no more not being able to stop, no more pulsating brake pedal on dry pavement.
If you want ABS then you will have to go and have the ABS codes read at the dealer, unless you can find a mechanic who can read Rover ABS codes, I couldnt.
If you get the codes read then you can see how much ABS is worth to you, starting price is $400, it goes up from there.
Old Oct 17, 2008 | 09:44 AM
rsm688's Avatar
Thanks for the tip, that fuse is going bye bye. I could care less about ABS, and Im a broke college student. Even $400 is way more than I have to spend.
Thanks,
Spencer
SolAeon
Jul 10, 2012 09:05 AM
ctystrickland
Feb 15, 2011 07:54 PM
tibyABv6
Jan 7, 2011 06:02 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
