Brake Problem
Old Apr 9, 2010 | 12:49 AM
bantham1's Avatar
Default Brake Problem
I am continuing to have a brake problem. I replaced the MC b/c it was leaking and sometimes my brake pedal would travel farther to the floor, especially when driving on the interstate without touching the brakes for a while and then trying to stop. Pumping the brakes once when this happens makes the travel reduced and pedal firmer. Could I have received a defective Master Cylinder? I have bled the brakes at all 4 wheels but could not get the ABS module to activate. I also bled the Master Cylinder before installing. Vehicle is 1998 D1
Old Apr 9, 2010 | 01:02 PM
Willie00d2's Avatar
A shop can make the Abs Module run while they blead the system. When changing a ABS module you are supposed to do this, I don't know if you need to make it run when changing the master cylinder. You might have air trapped in the ABS module.
Willie
Old Apr 10, 2010 | 12:38 AM
bantham1's Avatar
I read you can bleed with a certain key/brake pedal procedure. Does this work on a D1?
Old Apr 11, 2010 | 01:12 PM
bantham1's Avatar
Anybody have any clue as to what is wrong? How do I activate the abs module to bleed?
Old Apr 11, 2010 | 01:38 PM
greg409's Avatar
how much fluid did you purge thru?
The norm is at least (2)qts. (not pints)
I did (3) qts. they work the best they have in (5) years.
The manual says do it with the engine off.
luck,greg
Old Apr 11, 2010 | 01:53 PM
Baylink's Avatar
The manual also says "hook it up to testbook, and navigate to the menu item that runs the ABS modulator".
Indeed, you'll have that same symptom -- as do I on my DII -- if you don't. On the second pump, they're decent, but before that, not so much.
Old Apr 11, 2010 | 02:20 PM
bantham1's Avatar
I purged two big bottles of the valvoline synthetic till fluid was clear. Is there a way to activate the pump without testbook? I tried the three pumps with the brake pedal and hold for 60 seconds while the key was on the 2nd position, but this did not work. Do I need to do this with the bleed screw open?
SolAeon
Jul 10, 2012 09:05 AM
ctystrickland
Feb 15, 2011 07:54 PM
tibyABv6
Jan 7, 2011 06:02 AM
Florida04RR
Mar 10, 2010 06:09 AM
bigbris1
Jul 3, 2007 08:02 PM
