Brake questions
Brake questions
First off, I need to get longer brake lines (looking at SS atm) for the vehicle. I have a 2" suspension lift and I will be wheeling without sway bars. Any recommended lengths?
Also I want to remove the brake dust guards because crap keeps getting stuck in there and making a lot of noise until I blast it out. Do they serve any real purpose on the Rover?
And my final question, getting longer brake lines is easy, but what about the ABS sensors on each wheel? Can I cut them and add more wire or is there another way?
I'm going to pick up some braided line from the off road warehouse next to me, it is a quarter of the cost for materials. I was just curious about how much longer i should make them.
And I'll look into the ABS extensions. Sounds like the only viable route.
I bought a 2" lift (4 new coil springs and 5 shocks) from Old man emu
I didn't think about the ones on the firewall, I'll be sure to check them out. Also I bought some HD Springs and I've tested out driving on and off road without the rear sway bar. Much better performance in my opinion. I was mindful of the short brake lines however so it is moving up on my priority list.
And I'll look into those ABS extensions. Thank you.
avking
02-18-2009 05:10 PM
