New brake pads...questions??
Old Nov 26, 2009 | 04:59 PM
VToffroad's Avatar
Default New brake pads...questions??
haven't been on in awhile. Over the summer i put in a 3" big blue lift kit and an ARB brush-guard. Along with that, i put on a roof rack with two 7" hellas on the front with a work light on the back. I also put a CB in for talking with my buddies. Im putting new brake pads in tomorrow before i go back to school and saw that there is a special socket needed to remove the rear calipers?? its shaped like a star bit but has more sides...does anyone know what i mean? i believe it holds the calipers to the rear hub? Thanks for the help!
Kyle
Old Nov 26, 2009 | 05:02 PM
kenk's Avatar
What year truck? On my '98, you don't have to remove the calipers to replace the pads. On a D2, i believe all you need is the correct size 12pt socket.
Old Nov 26, 2009 | 05:06 PM
VToffroad's Avatar
its a 97...so if i dont remove the calipers..is there a special way to return the piston into the caliper? thanks again
Old Nov 26, 2009 | 05:11 PM
kenk's Avatar
If they're( there's 2, an inside and outside one) not too sticky or frozen, you should be able to push them in with a large screwdriver, racthet handle,etc. Otherwise, you need a c-clamp with a thin front jaw on it. I just took a regular c-clamp and ground the strenghtening rib off the front so it'd fit down in.
Old Nov 26, 2009 | 05:15 PM
VToffroad's Avatar
Ok cool. Sounds like a pretty simple job of removing the cotter pins, pulling the old pads out, opening the brake reservoir lid, and squeezing the pistons back into the original position and dropping new pads into place? I will keep that c-clamp idea in mind for sure! if you have any other tips that would be cool as well. Thanks
Kyle
Old Nov 26, 2009 | 05:17 PM
kenk's Avatar
Nope, it's that easy. By far easiest pad job I've done. As long as the pistons slide nice-n-easy. I'll add, some say to crack open the bleeder screw instead of pushing old fluid back into the reservoir.
Old Nov 26, 2009 | 05:19 PM
VToffroad's Avatar
cool! thanks for the quick response. Im sure i will be back soon with more maintenance questions since rovers are always in need of work.
Old Nov 26, 2009 | 10:32 PM
oysterhead's Avatar
i'll fill in for disco mike: use lots of sound deadening spray to prevent brake squeak.
Old Nov 27, 2009 | 10:36 AM
Don't do a brake job if you haven't also repacked the wheeling bearing and in the case of the front brakes, serviced and adjusted your swivel joint. Not servicing your truck properly will cost you big in the long run.
Florida04RR
Mar 10, 2010 06:09 AM
tsuami1
Aug 28, 2009 04:24 PM
ljdiscovery
Jan 17, 2009 01:35 PM
sparky
Apr 13, 2008 09:13 AM
william
Sep 24, 2006 02:41 PM
