Are the brake rotors serviceable?
Old Apr 8, 2008 | 08:45 AM
CandiMan's Avatar
Default RE: Are the brake rotors serviceable?
In preperation formy upcoming 4-wheel brake job, I was looking through my service manual and had a question.From looking at the two pics, does anyone know what size thefront and rear axle nuts are?
#7 and #9 front axle
#5 and #7 rear axle
I assume all four nuts are the same size. I'm hoping the LR axle nuts are of similar size for most FWD axle nuts, becasueI do have a couple FWD axle nut sockets. Knowing the socket size will prevent me from runningto the parts store when doing the job.
Old Apr 8, 2008 | 09:53 AM
Atlantic British sells a socket to remove the hub bearing, it is a 2 and 1/16th 6 point.
Make sure you have a new seal kit , including new grease seal for both the front and rear and well as sound deadening material for the brake pads.
Old Apr 16, 2008 | 08:17 PM
CandiMan's Avatar
Misson completed. All four rotors and pads have been changed.The hubs the designed just like heavy duty truck axles/hubs that I deal with at work.Just on a smaller scale.
I mentioned in another thread that my right rear caliper mounting tabs were broken. So I got another caliper anddust shield from the salvage yard.
Install salvage caliper just to make sure I would have no issues. Fits like a glove
This is a comparison between the old right front rotor and the new replacement rotor. Words can not explain.
Left front axle axle all cleaned up and ready for re-assembly
Seperation of the front hub and rotor
Repack front bearings, adjusted the bearing/hub, mount caliper and install pads. It took extra time and care to clean the right front caliper. With the piston being so far out of the bore I had to take time and clean/polish the piston before pushing them back in. They had all sorts of dirt and debris on the piston.I didn't want todamag the caliper seal by pushing in a extremely dirty piston.
Did the same for the rear axle/hubs. Removal, clean, repack, install and adjust.
I assume for those models that don't have the capability to monitor front pad wear, we can just cut the connector harness off?
All in all, for the fisrt time doing a brake jon on a Land Rover it was an easy process for me. Being familiar with the hub/axle design really helped in my favor.
Old Apr 16, 2008 | 08:20 PM
CandiMan's Avatar
BTW, to save a few bucks I did buy the pads and rotors off eBay. $183 shipped for all fours corner.
bcolins
Sep 14, 2015 01:10 PM
Washington Rover
Feb 13, 2014 10:27 PM
wrongway1
Audio/Visual Electronics
Dec 30, 2012 06:16 PM
fire1427
May 26, 2007 09:20 AM
jstreet
Jul 4, 2006 03:36 AM
