brake system crunch sound at start
Old 03-28-2011, 10:21 AM
twaszak's Avatar
Default brake system crunch sound at start
Hello all,
Sometimes when I start my Disco, as I press the brake pedal, turn the ignition, and the engine starts, I hear a half second "crunch" sound as the power assisted brake system becomes energized etc. The sound only happens when my foot is pressing the brake pedal at start. No crunching sounds while driving and in operation etc.
Brakes seem to be working fine at the moment.
I don't have enough brake experience to know what this means or what it might indicate etc.
I'm guessing air in the system and that a brake fluid replacement and a brake system bleed might be in order. But I'm only guessing.
As with almost everything else on my Disco, I'll be fixing this myself. Any insight about what the "crunch" sound might indicate and/or foretell, and any advice, and/or recommended next steps will be greatly appreciated.
Thanks,
Thomas
Old 03-28-2011, 10:34 AM
Snafu / Disco Fries's Avatar
Is it the same sound like when the traction control kicks in?
Old 03-28-2011, 02:42 PM
twaszak's Avatar
Yes... the sound is similar if not the same sound as when traction control kicks in. It makes that sound often when I start the engine but not every time.
Old 03-28-2011, 03:19 PM
yloDiscoII's Avatar
Mine does it too, completely normal.
Old 03-28-2011, 03:37 PM
Bundu's Avatar
Banned
Don't press the brake when you start
Mine does some weird thing as well, so I don't touch the brake.
Old 03-28-2011, 07:28 PM
twaszak's Avatar
Ok.... Good...
I'll find something else that can go bad to worry about then
Thanks for the sanity check...
Cheers,
Thomas
Old 03-28-2011, 11:26 PM
sloppyjoe's Avatar
its the ABS and TC energizing. No worries
armyeng
03-08-2011 05:58 PM
ctystrickland
02-15-2011 07:54 PM
mvjimenez
06-12-2010 10:25 AM
senortetas
Audio/Visual Electronics
01-05-2007 07:07 PM
disco12
02-08-2006 03:59 PM
Quick Reply: brake system crunch sound at start
