Brakes
Old Oct 8, 2012 | 05:25 PM
bcball's Avatar
5th Gear
Default Brakes
Hi
Not sure if this is covered anywhere else, if it is i apologize.
While driving home from work last week in a heavy downpour the warning lights for the Brake, ABS, Traction Control and Hill Descent came on when I applied the brakes. They went out shortly after but came on again the next day and stayed on. I checked the brakes and found the rear pads gone and the rear calipers seized. I had the pads and calipers replaced, but the lights are still on.
Is there something else that should be done?
My nearest dealer is 450km away and I don't want to make the trip unless absolutely necessary.
Any help would be greatly appreciated.
Thanks
Brian
2003 Discovery II
SE7
Old Oct 8, 2012 | 05:27 PM
Antmen's Avatar
Do a search for "Three Amigos" and you'll find TONS of info.
Best of luck! It's the DII owner's curse, but it can be remedied.
Old Oct 8, 2012 | 05:54 PM
lr2001silver's Avatar
Banned
There was a very recent post asking the same question and same situation. Use the search bar at the top of the page for quick search results. Good luck with you abs system
Old Oct 9, 2012 | 10:35 AM
bcball's Avatar
5th Gear
Default Thanks
Thanks for your quick responses. I have done some searching on the "3 Amigos" and it looks as if it is a problem not easily solved by the backyard mechanic!
Maybe I will have to take it to the dealer and let them have a look at it.
Once again thank you.
Old Oct 9, 2012 | 11:04 AM
drowssap's Avatar
if you list your location someome in the area with the proper diagnostic tool may be able to help you out or point you to a indepenent shop that can help you.
Old Oct 9, 2012 | 12:31 PM
Where are you located? It might be cheaper for you to buy a $200 3 amigo scanner test it, repair it and clear the code then having to do with a shop where it will cost you alot more. Then you can resell the scanner on line for $150 or more to recover some of your total cost.
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
BigMike
Mar 30, 2006 09:45 PM
bakerww
Jan 30, 2005 10:36 PM
