Brakes, then no Brakes
Old Jan 19, 2007 | 07:14 PM
Blatallic's Avatar
Default RE: Brakes, then no Brakes
Good luck man and keep us informed....
Old Jan 19, 2007 | 07:57 PM
1eyescooter's Avatar
Apparently I forget to reload the master cylindar before I put it on. 30 degree rainy weather would make most forget what they are trying to do. Once I get the advice I need I am going to put the master cylindar on properly. If that doesn't work I found a break booster off a 96 Disco for only 75 bucks. I'll keep you posted.
Nikki
Old Jan 27, 2007 | 06:11 PM
On Friday we put the brake master cylindar on the proper way and I still have no brakes. I am in the same boat as I was before we changed out that part. I have enough brakes to get me up the street as long as I stop way back. I can still pump the brakes and get more tension, but the pedal still goes to the floor. I am out of ideas other than the booster that someone else mentioned. Does anyone have any other ideas, comments or should I try to change out the booster? I really need some help on this. No car means I can't do my day to day things and I can barely find rides to work. PLEASE HELP!
Nikki
Old Jan 28, 2007 | 09:05 PM
mr.47's Avatar
Hi
Have you ever bleed the brakes. It could have air bubblessome wherein the brake line or the abs system.I hope this solves your problem. Good Luck.
Old Jan 28, 2007 | 11:43 PM
I bled the brakes before I even started to look for the problem. I got the easiest thing out of the way first. I have since bled them eech time the brake master cylindar was installed. Thanks for the feedback. Any other ideas would be great, or if someone could just tell me I am on the right path. Thanks guys.
Nikki
Old Jan 31, 2007 | 07:16 PM
Just in case anyone reads this in the future I will sum up what the problem ehded up being. Not knowing alot about cars, I was not aware that there is a rear brake master cylindar. I took my truck to the shop today and once they got it up on the lift they noticed that there was fluid coming out of the rear. They are going to work on it over the next couple of days. If it turns out that there is any other problems I'll post and let you know.
Nikki
Old Feb 1, 2007 | 11:12 AM
Nikki,
There is no rear mastercylinder on any vehicle much less your Disco, which makes me wonder what your mechanic is talking about. Make sure you find out exactly what he is talking about before you authorize any work.
Mike
MurphyPeoples
Mar 11, 2015 06:01 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
jeffmalone
Mar 13, 2010 09:23 PM
1eyescooter
Jan 15, 2007 08:48 PM
Lighting90
Off Topic
32
Nov 30, 2006 04:49 PM
