Breather tube axle fitting
Old Jun 15, 2022 | 08:18 PM
greisinb's Avatar
Default Breather tube axle fitting
Ok, so in the front axle there is a brass fitting that is pressed in to the axle in to which the breather tube is inserted. It’s a press to connect fitting but the plastic retainer has broken so the tube doesn’t stay in.
Has anyone had any luck prying that out and replacing it? If it can’t be replaced I could tap it and fit a new screw in fitting but I still have to get the old one out.
Old Jun 16, 2022 | 12:11 AM
JohnZo's Avatar
Maybe give some epoxy a go first. JB Weld to the rescue!
Old Jun 16, 2022 | 07:40 AM
greisinb's Avatar
I thought about applying some silicone and at least using that as a temporary fix to secure the breather tube to the fitting.
greisinb
Jun 13, 2022 10:41 PM
twin6
Feb 11, 2017 05:18 PM
TripleThreat
Jan 2, 2015 02:01 PM
dusty1
Apr 30, 2014 09:42 AM
lordmorpheus
Jun 24, 2010 08:33 PM
