Where does this tube/pipe goto?
Old Feb 11, 2017 | 12:52 PM
twin6's Avatar
Default Where does this tube/pipe goto?
Saturday fun. Just replaced the heads now putting the top half on and need to figure out where this black pipe (broken now) terminates to?
Any takers?
Attached Thumbnails Where does this tube/pipe goto?-img_2629.jpg
Old Feb 11, 2017 | 01:11 PM
LR03NJ's Avatar
Any takers?
Looks like a breather tube.
Old Feb 11, 2017 | 01:50 PM
twin6's Avatar
Anyone know where I can buy a replacement?
Old Feb 11, 2017 | 02:21 PM
Red5's Avatar
It's not broken, that's how it should be. Trace it down and it should connect to the front axle tube.
Old Feb 11, 2017 | 02:22 PM
OffroadFrance's Avatar
X1 ........... that or a vacuum tube, but my money is on a breather tube.
The tubes above are usually brake tubes, steel tube coated in plastic.
You also need to put a mesh across the heater air intake and clear out the debris first or you'll end up with a blocked heater. In one of the recent D2 posts someone found a really good deal on these heater mesh's.
https://landroverforums.com/forum/di...34/#post595366
Old Feb 11, 2017 | 02:24 PM
OverRover's Avatar
I don't remember the size of the tube, so measure the OD and ID and go to any NAPA, Advance, AZ and get some Nylon Fuel Hose.
It comes in a roll ,or you can just buy a short "Nylon Fuel Repair Line Kit". Either way it's cheap and you won't need very much to make the splice. You will also need a short (2" or less ) piece of coolant hose the same OD as the nylon hose to make the splice (like a plumbing slip joint).
Old Feb 11, 2017 | 05:18 PM
Friday Night Disco's Avatar
That is the EXACT tube I was looking at last weekend. I went to a friends shop and he said it is supposed to be like that. He then showed me on another D2.
Chrisw7562
Jan 16, 2017 10:24 AM
DiscoPhipps78
Nov 23, 2012 02:53 AM
JoMar
May 15, 2011 07:36 AM
chwelch
Apr 11, 2010 07:39 PM
96bRover
Oct 20, 2005 11:57 PM
