Breather tube axle fitting
Ok, so in the front axle there is a brass fitting that is pressed in to the axle in to which the breather tube is inserted. It’s a press to connect fitting but the plastic retainer has broken so the tube doesn’t stay in.
Has anyone had any luck prying that out and replacing it? If it can’t be replaced I could tap it and fit a new screw in fitting but I still have to get the old one out.
TripleThreat
Jan 2, 2015 02:01 PM
