Brief Smoke at Header After SeaFoam
Old Aug 19, 2008 | 09:44 AM
04BluDisco's Avatar
Default Brief Smoke at Header After SeaFoam
Hi,
Did the induction cleaning with SeaFoam (thanks to DiscoMike for the info and patience!). Not as much smoke as I had expected by reading the post, though I did get a good 2 minutes of neighbor smoke screen. I did notice that I was getting a bit of smoke from the joint between the passenger side exhaust header and the pipe.... Nothing too serious, and it went away... has anyone experienced this? Indicative of a slight exhaust leak, I would assume?
Thanks
Jason
'04 Disco 2 - 60,000 miles
Old Aug 19, 2008 | 03:09 PM
Default RE: Brief Smoke at Header After SeaFoam
The smoke can be normal, usually a sign of a failing exhaust manifold gasket.
Something didn't work righ, you should have had excessive smoke while driving hard for at least 20 minutes.
Old Aug 19, 2008 | 03:18 PM
It shouldnt smoke to bad if it was already clean.
Old Aug 19, 2008 | 03:25 PM
04BluDisco's Avatar
Just to clarify, I got a ton of smoke *(massive amounts to smoke out the neighborhood), but only for acouple minutes... When I took it out for a drive, it did smoke for 20 minutes or so, but not massive amounts... looked more like driving with an oil leak in a valve guide....
Old Aug 19, 2008 | 06:16 PM
IDAHODISCO's Avatar
Thats what mine did too! I thinks its cuz it wasent that dirty.
Old Aug 20, 2008 | 07:51 AM
remac's Avatar
Is there a link someone can post as to how to do the seafoam cleaning?
arains44
Jan 1, 2013 08:14 PM
Disco Joe
Jan 5, 2011 11:40 PM
LaurenSorensonx3
Aug 13, 2009 05:10 PM
kfx4001442
Jun 23, 2009 05:33 PM
Bobbie Digital
May 6, 2008 07:35 PM
