Britpart steel bumper alignment?
Old Jan 11, 2021 | 10:18 AM
Chris59's Avatar
Default Britpart steel bumper alignment?
Had anyone installing the britpart rear bumper had a problem with alignment. Mine pushes up the plastic trim at both corners - even broke one. The 2 welded in spacers above the tow hitch plate seem to push the bumper too high.
Do I need to remove those spacers?
Old Jan 11, 2021 | 05:07 PM
Richard Gallant's Avatar
Yup same problem, but as it is the rainy season right now so I am living with it. My plan is to loosen everything off, then tighten just the center bolts and see what happens if it stays level then the outside bolts are the issue. But I think it is the center causing the issue as it is the same on both sides. In which case a bit of bending should correct it.
Old Jan 11, 2021 | 05:30 PM
Chris59's Avatar
Bending that piece of steel doesn't seem easy, but that should help. I also considered using some thicker spacers between the bumper and frame - but aligning on my own was tough and I'd rather let those bolts screw in as far as possible.
Old Jan 11, 2021 | 05:43 PM
@chris59 they used to use a lever type device to adjust bumpers when they were steel, youtube example
Something similar should work, used at the center and worked outward
Old Jan 11, 2021 | 06:20 PM
Harvlr's Avatar
That tool looks cool Richard, but I don't think it will work on your bush bumper. The rear bumper that was on my D2 when I got it was bent. It was 2X4X1/8" rectangular steel tube. I put my floor jack under it to straighten it. With the whole weight of the rear corner of the truck on it, it didn't budge. With the jack still on it, I took a 16lb sledge hammer to it and it still didn't budge. I think your Britpart bumpers are similar construction to this. (I looked into the Britpart bumper, but in the end I made my own. When I replace the front I'll seriously consider a Britpart bumper).
Old Jan 11, 2021 | 06:28 PM
@Harvlr I hoping I can rent one or DIY one to try. Bending the center portion should be doable, but as you know it has been a little wet for that kind of thing in the driveway. In my case it is not much, I can make an angled shim easy enough it is just a ton of fiddling, marking then welding the shim in place on the bumper so it can not move.
Old Jan 11, 2021 | 06:42 PM
Chris59's Avatar
Originally Posted by Richard Gallant
@chris59 they used to use a lever type device to adjust bumpers when they were steel, youtube example https://www.youtube.com/watch?v=yjtOmEISfO8
That bumper looks like cardboard compared to the britpart one, but I suppose enough leverage might atleast help get the bolts more aligned.
Old Jan 11, 2021 | 06:57 PM
@Chris59 maybe but they used them on Pickup bumpers too,hard to say without trying.
Old Jan 11, 2021 | 07:03 PM
Chris59's Avatar
fair enough, might give that a try. It’s a great looking bumper - just a little off
WeekendWarriors87
Aug 29, 2022 09:03 AM
hankeester
Jul 7, 2022 09:55 AM
jogan
Nov 17, 2020 04:19 AM
TOM R
May 23, 2016 09:06 PM
mirrajumper
Nov 15, 2012 07:57 PM
