Broke this. Can it be fixed ?
Old Feb 11, 2011 | 07:28 PM
FightOnUSC79's Avatar
Default Broke this. Can it be fixed ?
Clip on right side underneath dash that allows access to fuses. ANyone have one break off and is there a fix that doesn't involve taking the dash apart? From what i can see (which is limited) looks like it may have been a piece built into the lower dash panels and not attached.
Thanks
Old Feb 12, 2011 | 11:42 PM
wa3ra's Avatar
It sits in the dash behind the cleco-style fastener. You can reach up with the fuse door open and set it back into the opening. You can use Goop or epoxy to hold it in permanently. After it dries, you'll be able to use it correctly again.
It is easy to break out, if you try to open the door with the fastener not completely cleared.
yay4me.disco
Apr 20, 2014 08:55 PM
94svt50
Nov 25, 2011 11:08 AM
aremee
Nov 19, 2006 12:03 AM
aremee
Nov 17, 2006 12:01 PM
