Broke Radiator Bleed Hose
Old Jul 16, 2016 | 10:36 PM
huggi's Avatar
Default Broke Radiator Bleed Hose
Hey guys, new here. Recently got a 2003 disco, was trying to check the air filter and broke the radiator bleed hose - see attached picture of hose I broke.
Where can I find a replacement hose?
Thanks
Attached Thumbnails Broke Radiator Bleed Hose-radiator-bleed-hose-2.jpeg   Broke Radiator Bleed Hose-radiator-bleed-hose.png
Old Jul 16, 2016 | 11:47 PM
Bom2oo2's Avatar
If fadiator nipple is ok then just get few feet of radiator rubber hose and replace that plastic brittle hose going from radiator to coolant reservoir,, that's what everybody does, (can get it from most auto part stores that seek it by foot),,,, while doing it also replace the other brittle hose going from truffle body heater plate to coolant reservoir also,( is its still ok, do it anyway it will also break very soon),
Old Jul 16, 2016 | 11:48 PM
Bom2oo2's Avatar
Be careful not to break the nipples , on radiator and coolant reservoir when replacing hoses, they are also brittle,,
Old Jul 17, 2016 | 07:13 AM
huggi's Avatar
Thanks will do, do I have to bleed the coolant system after replacing the hose?
Old Jul 17, 2016 | 07:51 AM
Bom2oo2's Avatar
Yes bleed,, shouldnot be much air in cooling system, but it's a good idea to bleed after any hose change or coolant lose, just don't over tighten bleed screw, remember it's the O-ring that makes the seal,,
LR03NJ
Nov 25, 2015 07:16 PM
Tristan Marineau
Jun 5, 2015 07:50 AM
MARGE
Feb 29, 2012 05:24 PM
G Reeves
Feb 23, 2012 04:46 AM
joatman
Jan 27, 2009 12:13 PM
