Radiator hose Tee BROKE
Old Nov 25, 2015 | 01:17 PM
LR03NJ's Avatar
Default Radiator hose Tee BROKE
Just got an emergency with the radiator hose Tee - BROKE!. Need car, parts need to order but Thanksgiving. Can I use a Copper Tee from home depot? Please respond before they close. Thank you guys!
Old Nov 25, 2015 | 01:47 PM
OverRover's Avatar
The short answer is yes. It's not a hard fix and most go with Galvi pipe like this>>
https://landroverforums.com/forum/di...f-value-64502/
https://landroverforums.com/forum/di...fitting-65884/
Old Nov 25, 2015 | 04:46 PM
LR03NJ's Avatar
Thanks. Actually I run to homedepot earlier and purchased the brass Tee for $8 and installed it. While I was there I used a 2 ball pin hammer to widen all the ends so the hose wont slide out. So far it works.
Old Nov 25, 2015 | 05:42 PM
mln01's Avatar
I'm glad you solved your immediate problem. Do you know what caused it to break? I'm not aware of that happening spontaneously.
Old Nov 25, 2015 | 07:16 PM
LR03NJ's Avatar
It started leaking. After a while, I thought the clamp was loose so I bought a screw type pipe clamp. The plastic got brittle already and start to crumble. It disintegrated inside the hose. You can actually chip the plastic with your fingers.
Tristan Marineau
Jun 5, 2015 07:50 AM
NickAdams
Dec 26, 2012 12:16 PM
onewingman
Oct 12, 2012 01:56 PM
slanginsanjuan
Apr 2, 2012 06:56 PM
G Reeves
Feb 23, 2012 04:46 AM
