Broke this while doing pulley belt replacement
That cover is nothing more than cosmetic.
Watch this video from AB and it will show you how remove the fan:
https://www.roverparts.com/resources...t-discovery-2/
on
so the bolt That I broke also serves no purpose other than holding the plastic bit down?
OK, cool. I have removed stuck fan nuts using a pair of vicegrips onthe water pump pulley. If that doesn't do it you can change pump, fan, clutch, and waterpump all at once but it is not easy. I always put neverseize on the fan threads but not all mechanics before me are so kind. Frankly a large number of them need to have their asses kicked.
JohnZo (06-23-2021)
Re the bolt. On ACE cars that also holds the ACE pump and the cover. But it looks like you have a spacer on there, which I guess is what non-ACE cars have ... so it's probably fine that it broke.
Literally ANY bolt on either of my Rovers I'm going to take off underhood or underneath, I spray with something designed to help you get stubborn bolts out the day prior if I can. It's a good practice.
whowa004 (06-23-2021)
