Broke this while doing pulley belt replacement
Old Jun 22, 2021 | 09:09 AM
Oshawa_D2's Avatar
Default Broke this while doing pulley belt replacement
While taking the cover off compressor cover broke this bolt that holds it down was totally seized
what to do?
also I cannot get the fan to move at all
any advice? I am afraid of breaking the fan bolt
Old Jun 22, 2021 | 09:13 AM
redwhitekat's Avatar
It’s the cover bolt ? Who cares
I have a long adjustable wrench and I wack it good with a rubber mallet
Old Jun 22, 2021 | 10:03 AM
whowa004's Avatar
Sometimes the mallet trick isn't enough. They make an air tool for fan removal that is super slick, might be able to rent one from a local parts store.
Old Jun 22, 2021 | 10:39 AM
matt3502's Avatar
That cover is nothing more than cosmetic.
Watch this video from AB and it will show you how remove the fan:
https://www.roverparts.com/resources...t-discovery-2/
Old Jun 22, 2021 | 10:44 AM
Oshawa_D2's Avatar
I tried that with no luck it will not budge. Regardless I worked my way around with the fan on.
so the bolt That I broke also serves no purpose other than holding the plastic bit down?
Old Jun 22, 2021 | 01:16 PM
Extinct's Avatar
Based on the crusty bolt I am a little scared of the fan situation. Why are you taking the fan off?
Old Jun 22, 2021 | 02:33 PM
Oshawa_D2's Avatar
I wanted the fan off so I have easier access to the pulleys and the serpentine belt however I’ve managed to change them without taking the fan off
Old Jun 22, 2021 | 02:42 PM
where did you buy the 2 pullies and tensioner ?
Old Jun 22, 2021 | 06:40 PM
Extinct's Avatar
OK, cool. I have removed stuck fan nuts using a pair of vicegrips onthe water pump pulley. If that doesn't do it you can change pump, fan, clutch, and waterpump all at once but it is not easy. I always put neverseize on the fan threads but not all mechanics before me are so kind. Frankly a large number of them need to have their asses kicked.
Old Jun 22, 2021 | 11:06 PM
nashvegas's Avatar
Re the bolt. On ACE cars that also holds the ACE pump and the cover. But it looks like you have a spacer on there, which I guess is what non-ACE cars have ... so it's probably fine that it broke.
Literally ANY bolt on either of my Rovers I'm going to take off underhood or underneath, I spray with something designed to help you get stubborn bolts out the day prior if I can. It's a good practice.
caspice
Nov 9, 2015 06:59 AM
FlyingZebra34
Jul 10, 2013 07:25 AM
adacus
May 1, 2010 01:42 PM
souljad9
Nov 19, 2008 11:50 AM
Panama Jack
Dec 8, 2007 09:01 AM
