Broken Serpentine Belt--overheat!
Old Feb 27, 2014 | 08:14 AM
bradman951's Avatar
Default Broken Serpentine Belt--overheat!
Hey All!
First of all, please save all of the lecturing about changing the serpentine belt before it breaks, yada yada, I get it LOL. Was driving to work today and heard a faint pop. Immediately my speedo dropped to zero and my battery light came on. Strange I thought, but pressed on. Figured I was almost to the office and would investigate there. Shortly thereafter, I was alarmed to see the temperature light come on and was frightened to see the temp climbing quickly into the red zone! Pulled over that moment and shut her down. Didn't take me long under the hood to see that the serp belt had committed suicide, leaving the rest of the engine components in despair. After allowing enough time for the engine temp to creep down into the safe zone, fired it up and got enough momentum to coast in to work with the engine off.
My question really is: is this short period of overheating enough to do serious damage to the engine? I know these aluminum heads are sensitive, and so are the sleeves. I'm all wigged out about it now.
Old Feb 27, 2014 | 02:15 PM
jfall's Avatar
Nice engine you had.
Old Feb 27, 2014 | 03:00 PM
jeffh's Avatar
thats a hard one to answer. I would get it all fixed, then do a pressure test after that, assuming you do not fail. I would do an exhaust gas in coolant test. Should that pass as well then for safety I would flush your coolant, put in a 180 thermo change out your oil and filter then go for a drive. Do you have an plug in temp gauge. If not I would buy one as well and get an actual read on your temps not the factory gauge.
Old Feb 27, 2014 | 03:20 PM
grandkodiak's Avatar
No belt, no water pump, no circulation, coolant temp is by radiator... wait, these pumps are gear driven... you might have gotten lucky
Old Feb 27, 2014 | 04:43 PM
earlyrover's Avatar
You: "Strange I thought, but pressed on." YOU COMMITTED SIN NUMBER ONE, WHEN YOU "PRESSED ON." That is a no, no, a thing to never ever do, unless you don't mind risking wasting your engine. I know, you said no lecturing, but you deserved at least that much; lecturing is out of my system now; I feel better already.
You: "My question really is: is this short period of overheating enough to do serious damage to the engine? I know these heads are sensitive, and so are the sleeves."
Yes, ALL aluminum heads, Rover or otherwise, are prone to warping, when overheated. The sleeves, on the other hand, are not prone to any damage at all from the overheating, but the thin aluminum walls behind the cylinder liners, between them and the coolant jacket ARE "sensitive," in that they are likely to crack from such overheating issues, which, in turn, makes for a bit more room for liners to move within bored holes for liners, so if they can move, sometimes referred to as slipping, they may, due to piston/rings friction against inner walls of liners. The cracks in walls behind liners causes coolant to move downward, between the outside of liners and bored holes in aluminum, into the oil pan, as well as moving upward behind liners, & beyond the head gaskets, into the combustion chambers.
You: "is this short period of overheating enough to do serious damage to the engine?"
Yes it is more than enough time for damage as described above, but the important question is did it cause this damage? Nobody can tell you that, with certainty, unless they did some serious testing of the block, to assess if any cracking took place behind liners, and/or any warping of the heads took place. The only honest answer I can give you to your question, did damage happen? MAYBE! I personally wouldn't put a lot of money in it at this point, other than an obvious new belt, until it was definitely determined if damage has occurred. If it didn't, count your lucky blessings. If it did, chalk it off to experience; don't do this again in your lifetime, and send me a PM, and I will give you your options at that point, if you don't know them already.
Old Feb 27, 2014 | 05:10 PM
shezm's Avatar
I would get a new belt and see if it still overheats. If not then no worries!
Old Feb 27, 2014 | 07:26 PM
dr. mordo's Avatar
Check your idlers and tensioner while it's apart. A bad idler could have cause the belt to break.
Old Feb 27, 2014 | 08:08 PM
jfall's Avatar
Just put the new belt on,
Fill it with antifreeze.
Bleed it.
Drive it around.
See how it goes.
Old Feb 28, 2014 | 12:27 PM
bradman951's Avatar
Yes yes, point taken. Looked like an electrical issue to me at first since the speedo cut-out and battery light came on. I was literally half a mile from work so didn't think it would make a difference to stop right there on the shoulder or to wait 1.5 minutes to pull into the office and check it out. Never again!
You all pretty much confirmed what I was thinking about the whole situation. It could have caused severe damage or it could not have. I really won't know until I put everything together and see how long it lasts. Really have been wanting to do a diesel conversion on this truck--possibly this will expedite that process :/ Fortunately I only paid $1500 for this truck so if the motor ends up needing replacement, it won't be terribly unfortunate. Just not as good as not needing to replace it LOL. Ugh, oh well. Thanks for chiming in!
joshsrover
Apr 2, 2008 11:03 AM
aublec22
Sep 15, 2007 09:05 AM
Benhamtroll
Aug 17, 2006 11:45 AM
Thegix2
Nov 22, 2005 09:25 PM
esaycho
Oct 12, 2005 03:24 PM
