Brush Guard Lights
Old Feb 11, 2011 | 10:46 AM
  #31
JKFL03's Avatar
Which Way
Old Feb 11, 2011 | 11:21 AM
  #32
Snafu / Disco Fries's Avatar
Originally Posted by dcarr1971
I'm sure it probably could be done, but do you think it's a good idea to start cutting into your D2's electrical system without a 100% clear understanding of what every one of the wires does?
Yeah, this is pretty easy. I'm actually looking to do LESS modification my way. I would like to keep the current factory switch for the lights and the current wiring from the switch to the relay. The instructions said to modify a cruise control switch, run new wires, etc. It is a pretty easy set up after that.
Old Feb 11, 2011 | 12:14 PM
  #33
JKFL03's Avatar
Re: How to wire or hook up fog lights?
Here's a wiring diagram that might help:
do you think you can use the existing switch? I dont see why not, we may have lights
Old Feb 11, 2011 | 12:48 PM
  #34
Yep! I'm guessing instead of tapping the lights like said there, the existing wires to the high beam in the fuse box would work.
Old Feb 11, 2011 | 02:07 PM
  #35
dcarr1971's Avatar
Thanks for the great info.. I just have a question, why do you see some relays wired different. They use the 86 for ground, and use the 85 for the switch?? they use the same 30 for hot lead from battery, and 87 to the output (lights). Thanks
Based on the diagrams you posted, you should be able to swap the 30 and 87 as their just opposite ends of the same circuit. My guess is that the same is true for the 85 and 86...one needs to be the ground, and the other needs to provide power to close the circuit in the relay, but from your question I'd gather that it probably doesn't matter which is which.
I'd suggest that you just go with whatever the relay says when you buy one.
Old Feb 12, 2011 | 07:13 PM
  #36
Success (for the most part)! So, went out and got a basic relay like shown. I was able to hook it up and have them fire when the high's come on. The switch is totally out of the equation now. I would like to have them switchable though, so I still need to figure that part out. I will take any advice on how to wire that up. The unused wires I have are:
Red and Blue coming from factory switch
White which is live when the ignition is on regardless of what lights are on.
What I wired:
Fused positive from battery
Negative to chassis
Both positives from lights together (negative now both to the chassis)
Blue/Orange from the high beams as the trigger.
Any ideas on how to get the switch to work? Totally stumped. Blew out a few fuses trying things out, and would rather now press my luck!
Old Feb 13, 2011 | 05:53 AM
  #37
Urban Panzer's Avatar
the factory switch is "momentary", so it does not work in the same way as a latching switch, hence I modified mine with a cruise switch to keep the same "function" as the factory look / setup.
The only way it could be done using the momentary switch is to use a latching relay that when +12v is applied it latches in, but stays latched in even when the +12v is removed, and then is unlatched by applying +12V again.
Old Feb 13, 2011 | 08:13 AM
  #38
That would be fine, but I just can't figure out how to get the switch to actually work the lights. Whether it is the factory switch or the cruise switch I don't care, but need to figure it out!
Old Feb 13, 2011 | 10:57 AM
  #39
JKFL03's Avatar
Snafu, looks like I got you opposed. I the same way. Have you pulled the existing switch out to see what wires go in to it and out. I got mine working, they work only with High beams, if I switch them off, I have to push them back on. No big deal.
Old Feb 13, 2011 | 06:38 PM
  #40
All the details are on the page / link I posted.
