A bunch of warning lights . . .
Old Mar 14, 2007 | 07:02 PM
Benhamtroll's Avatar
Default A bunch of warning lights . . .
Okay, I was driving back to work after lunch today when my car went ding and the Traction Control, Downhill Assist, and ABS lights all came on. What am I looking at here?
Chris
Old Mar 14, 2007 | 09:34 PM
Default RE: A bunch of warning lights . . .
I am sorry, I couldn't resist.
You are looking at a bunch of lights, also know as the 3 amigos, the Xmas trio and may other names.
You have thrown a fault code for your ABS system. Is your ABS system still working if you ge on the brakes hard?
Mike
Old Mar 15, 2007 | 03:42 PM
Aquaholic's Avatar
Did they go away the next time you turned it on?
Old Mar 15, 2007 | 04:08 PM
Yes, they all went off. I'm wondering if I was getting a false reading, due to the fact that I'm past due to get the pads replaced on the rear brakes . . .
Old Mar 15, 2007 | 04:12 PM
Aquaholic's Avatar
I dunno if it's a false reading or not, but mine did the same thing a couple weeks ago.
Old Mar 15, 2007 | 09:54 PM
eiggam's Avatar
5th Gear
my L/R 02 has a strange lite happenig also if put key which is worn in and just turn on hole uint the lite come on how ever if you be sure to be carfulley insert key turn to 2nd part of sw and wait for the lits to go off the lits will not come on any body els have this happen
Old Mar 26, 2007 | 05:32 PM
eiggam's Avatar
5th Gear
my L/R 02 has code 1592 can any one help
Old Mar 26, 2007 | 06:18 PM
Elhoff's Avatar
My three lights came on onceand went off when I restarted the truck. Everything seemed to be working fine so I chose to ignore it for a while, though I knew in the back of myhead that the pads needed to be replaced. After about two months, the lights came back on and stayed!I changed the pads, had the dealer clear the lights, and all has been good since.
Lesson: If you know your pads need to be replaced and the lights come on momentarily...Get those pads changed before the lights come on to stay!
Realistically there could be something else wrong, but since you know the pads need to be replaced, I would start there. If the lights stay off, and everything is working fine, you should be OK.
Old Mar 27, 2007 | 11:21 AM
Craig SA's Avatar
4th Gear
I had the same thing 2 weeks ago. The lights came on and the went off when I restarted it. They stayed off for about a week then came on again and stayed!
I had new brake discs and pads fitted all round and the one sensor propoerly seated and it has not come back.
bonedoc
Mar 25, 2017 12:54 PM
Big D
Oct 24, 2009 07:30 PM
UDPride
May 4, 2009 10:40 PM
nars1000
Oct 15, 2008 01:14 AM
oasisuk4
Apr 3, 2007 12:04 AM
