buying transfer case advice
Old Sep 29, 2010 | 02:41 PM
mrossipir's Avatar
Default buying transfer case advice
I am buying a used transfercase with 40k on it from a junkyard. Are there any parts (ancillary) which I should make sure are included in the purchase. I do not want to disassemble it at all, just put it in. I dont want to have to go to the dealer and spend money after the fact.
Old Sep 29, 2010 | 02:59 PM
NiteTrain's Avatar
try to get one with a CDL ('99-mid '01) and be sure to get shift lever if you don't already have one
Old Sep 29, 2010 | 03:01 PM
mrossipir's Avatar
agreed, I have cdl on my 2000 disco now, the one I am purchasing is from a 99 Disco series II. I think they are identical
Old Sep 29, 2010 | 07:28 PM
lordmorpheus's Avatar
They are.
Old Sep 30, 2010 | 05:46 AM
hilltoppersx's Avatar
have you rebuilt your front driveshaft with greasable u joints?
Old Sep 30, 2010 | 07:29 AM
Make sure the front shaft gets rebuilt to prevent it's failing and killing the tranny.
As for the install, changed out the t/case fluid, use only 85W/140 synthetic gear oil and replace the rear tranny seal and the front and rear's t/case seals before installing them.
Old Oct 1, 2010 | 04:45 PM
mrossipir's Avatar
Had the front driveshaft replaced 5k ago because of the 2 inch lift, all greasable ujoints. Will buy the new seals tomorrow. Also, the "high/low" lever on the new transfer case is very difficult to move back and forth. Is that normal and will it free up once I connect my existing cable or could it be an indication it may lockup in the future?
Old Oct 2, 2010 | 06:39 AM
you need to clean and lube it before you install it. it was most likely never used to shift from hi-lo and therefore is nearly ceased
srockrae
Dec 14, 2013 10:26 PM
marshman442
Oct 23, 2012 08:59 AM
TRIARII
Dec 29, 2011 07:13 PM
Phototone
Apr 7, 2008 03:59 PM
steveo
Jun 6, 2005 03:03 PM
