Buying used door actuator
Hello,
My two rear doors and driver front door power locks have failed and diagnosing it seems to be the actuator.
If I purhcase a used actuator will i be able to program the used actuator to match my current key thereby avoiding to have to replace my working front passenger door and rear trunk door actuators.
Pls. advice....if there is another better option pls. help...I am trying to avoid having to get new actuators from the dealer which is in the range of 250$ and up a piece. Crazy.
Thanks,
Gerard
Chicago
Thanks,
Gerard
Chicago
The Door Lock Actuators are hard-wired, slave devices that recieve a command from the Remote Lock Module. There is no programing required. The Door Lock Cylinder is seperate from the Actuator so your current key will still work.
I got my Actuator from here, they get $120 -130,
http://www.partsgeek.com/catalog/200..._actuator.html
kristofferzen
Sep 10, 2015 02:11 PM
bcolins
Sep 25, 2012 08:40 AM
jfall
Apr 12, 2012 03:26 PM
bcolins
Nov 8, 2011 06:15 PM
