A/C Blower Problems 96*F
Old Jun 27, 2008 | 02:49 PM
tailchaser0527's Avatar
Default A/C Blower Problems 96*F
Four days ago I noticed that my a/c blower would suddenly stop while making hard left hand turns.It would only turn off for about 1-2 seconds. Today, It wouldn't turn on at all. I don't have my rave cd handy, but I checked all of the fuses, and they're all fine, so I pulled the cover off of the blower, I can hear the relays click. Poked around with a test light for a few and noticed that the white/red and black/orange, heavy gauge wires that look like they plug into the motor don't get power at all.I'm gonna tryto get to my rave cd tommorrow(it's at my parents house).
In the meantime, any suggestions, advice, or experience with this problem?Itwould help a lot
Old Jun 27, 2008 | 07:26 PM
okdiscoguy's Avatar
Default RE: A/C Blower Problems 96*F
I assume you tried checking it in all of the various speed postions on heat and a/c....
Old Jun 28, 2008 | 12:12 PM
Phototone's Avatar
The fan speed selector switch is a known weak point, but you should get some blower action by jiggling the switch in most cases.
Old Jun 29, 2008 | 09:48 AM
Luv2Disco's Avatar
I had to have my entire blower replaced... fortunately, it was the week before my warranty expired. Hopefully this won't be your situation but just wanted you to know that the blower units do go out. I think a dealership repair was around $1200 so shop around if you need a new one
Good Luck
02 Disco II, 80K
Old Jun 30, 2008 | 10:58 PM
Alright, I finally got to my rave cd. I put 12v power manually to the blower motor, it's good. When the a/c is powered on there's no power to the blower motor. I checked the resistor pack with a standard test light, in all positions, there's no power to any of the wires on the resistor pack.
This leads me to believe that either the switch is bad, or Blower relay # R176 is bad. The relay only has power tothe small green wire (using the test light) in all positions.
If theblower motor switch is the problem,canI replacejust theswitch, or is that built intothe climate controlunit?
And yes, I've checked all of the fuses and different settings.
Any suggestions are appreciated. .. Thanks again for all the help..
Sonny13420
Jul 20, 2015 02:13 AM
Frank4
Mar 21, 2014 05:21 AM
Rigndip
Nov 22, 2013 07:53 PM
JJones82
Jul 14, 2012 07:22 PM
odess
Feb 6, 2012 01:25 PM
