99 range rover blower problems
Old Feb 6, 2012 | 11:20 AM
odess's Avatar
5th Gear
Exclamation 99 range rover blower problems
hi, the book symble with exclimation mark came out and both bloers dont work. the fuses and relays are ok. the blend motor work. i cant seem to find out why both bloer motors dont blow any air.
Old Feb 6, 2012 | 11:49 AM
Book sysmbol means HVAC ECU thinks there is a fault. Fuses are #34 and 43; and common ground point is shown in attached page from RAVE, # E253
File Type: pdf
Old Feb 6, 2012 | 12:51 PM
odess's Avatar
5th Gear
Question 1999 range rover 4.6 hse blower motors not working
Some one help me please. What could cause both motors to not blow air?Is there a fan relay or blower resistor that would cause this ? I can here the blend motors working but wether the climate control is in ac or heat nothing blows out.I checked the fuses and both fan relays their ok. And the book symbol is on.
Old Feb 6, 2012 | 01:25 PM
Here's the factory drawing. The Body Electrical Control Module turns on two relays in the under hood fuse box, Aux power 1 and 2. Those relays, via the fuses already sent to you, send power to the two blower motors. The AC control module decides when and how fast they will run. There is a common ground point for the two motors, already sent. It is not practical to jump out or hotwire these fans.
File Type: pdf
Sonny13420
Jul 20, 2015 02:13 AM
jennywebb23
Mar 5, 2015 05:59 PM
Rigndip
Nov 22, 2013 07:53 PM
JJones82
Jul 14, 2012 07:22 PM
tailchaser0527
Jun 30, 2008 10:58 PM
