A/C Control Relocation
Old Aug 10, 2013 | 09:36 AM
dusty1's Avatar
my head hertz, seems like a lot of work.
Old Aug 10, 2013 | 10:47 AM
ralphobell's Avatar
No pain no gain.
The most work will be splicing and extending the cable.
Old Aug 10, 2013 | 12:53 PM
Work in a bright light, phone cable colors on cheap cable can be very close to each other. Color blind telco guys don't last long.
Old Aug 10, 2013 | 03:52 PM
ralphobell's Avatar
Oh if I had a nickel for every telco/data wire I have punched, beaned, or spliced. That is my former profession.
What about wire tap connectors? Then I don't have to cut the original cable, and can get another cable end off a junker.
Old Aug 11, 2013 | 09:54 PM
ralphobell's Avatar
Well here is the 1st step. I cut up the old center dash. ( I have another from ebay, because this one the tabs were all broken off, so perfect for this mod!)
Attached Thumbnails A/C Control Relocation-img_0122.jpg   A/C Control Relocation-img_0123.jpg
Old Aug 12, 2013 | 12:07 PM
SuperSport's Avatar
Dang, you're almost there! I really like that mod too. Would love to install a VERY clean looking Double DIN Touchscreen GPS enabled stereo in the old Stereo/AC position.
Old Aug 15, 2013 | 07:41 PM
ralphobell's Avatar
Overhead cut, Climate Control mocked up. Next up Fiberglass and Bondo. Then on to the task of extending the control cables.
Attached Thumbnails A/C Control Relocation-climate-control.jpg
Old Feb 11, 2014 | 09:28 PM
ralphobell's Avatar
Well this project had taken a back seat for a while. Tonight I finished assembling the wire harness. I ended up purchasing 18awg wire off of ebay for around $40. It consisted of 10 colors 50 feet of each. Which was plenty.
I cut 10 ft sections and then created a wiring diagram. The wires were spliced with uninsulated butt connectors and then individually heat shrinked. Once all the single wires were terminated and heat shrinked I heat shrinked the bundle at the connectors.
The overhead console is about 50% complete. I still have to figure out a way to fill the large gaps before I can bondo and paint.
Attached Thumbnails A/C Control Relocation-img_0288.jpg
Old Jun 22, 2015 | 08:59 PM
LA_Disco2's Avatar
Ralphobell - Did you ever finish this? I'm about to take on the same A/C control relocation in order to install an iPad in the dash.
RealRitzcracker
Jan 11, 2019 03:19 AM
meltdowndave
May 31, 2008 01:10 PM
Kraftyz51
Nov 19, 2007 07:49 AM
N.Franklin
Nov 13, 2007 08:06 PM
brickhouse
May 24, 2005 03:13 PM
