A/c drain location
Old Jun 27, 2017 | 10:23 AM
OverRover's Avatar
Originally Posted by Motorhead1
I didn't know you could remove the bottom flapper do-dad.
Yep, they come right out. Just push the bottom tabs aside and the nipple comes out. Because they get crusty, hit it with a little WD-40 first. Really not needed but it makes the tip come away easier.
Once removed you will be amazed at how much water drains out with the AC on. And on the flipside, when the nipples are in and blocked, why the water backs up so quickly into the interior.
Old Jun 27, 2017 | 05:41 PM
number9's Avatar
You may want to clean it up well and reinstall if possible depending upon your local tiny critter situation. Ants/roaches may like the easier access and some bugs may make nests that will need to be cleared out occasionally to keep drains open.
Old Jun 27, 2017 | 05:45 PM
Motorhead1's Avatar
About once a year I remember to flick the ends with my finger to make sure they aren't clogged, so far so good. Don't forget about the rear drains behind the tail lights....
Old Jun 27, 2017 | 11:05 PM
mln01's Avatar
Instead of coathanger wire I recall someone, somewhere, suggesting using plastic string trimmer line because it is more flexible and, I presume, because it won't pierce a soft rubbery hose.
Old Jun 28, 2017 | 04:23 AM
Luckyjayb's Avatar
I got the passenger seat out so i guess I'll take the driver's out and center console so I can get good access to em tommorow
Old Jun 28, 2017 | 08:20 AM
Best4x4's Avatar
I've neve seen them clog up much higher than the nipples.
As far as critters/bugs "anything" is possible but I've yet to find anything besides little tiny spiders crawl up there, die, and drain right back out lol.
Only time I had something jab into an a/c drain was on a Mitsubishi Montero (Gen 1), after I drove thru some tall grass off roading. A darn mexican hat flower hit the bullseye and stopped it up like a cork lol. The drain was no where near as protected like they are on a LR.
oljohnboy
Aug 15, 2020 10:50 PM
Snafu / Disco Fries
Sep 15, 2013 07:16 PM
Roveroh
Aug 7, 2008 09:42 AM
PITTDISCO
Jun 30, 2008 10:26 PM
skewett
Jun 3, 2007 08:15 AM
