A/C turning off
Old Jun 23, 2007 | 06:41 PM
rravenn13's Avatar
Default A/C turning off
1996 Disco When I turn the a/c on it is running ok and then it suddenly cuts off. and the a/c light goes off. The fan also stops blowing for a few sec. and then starts blowing again without the a/c. I can then turn the a/c on again and it will work for a period of time.
Old Jun 23, 2007 | 07:47 PM
Default RE: A/C turning off
Sounds like a possible relay. Does it happen on all fan speeds, does the compressor stay on when the fans go off?
Mike
Old Jun 23, 2007 | 08:09 PM
rravenn13's Avatar
It seems to happen more when the fan is on high. The compreser turns off along with the fan and then the fan starts again in a few sec without the compresser.
Old Jun 24, 2007 | 08:39 AM
You could have a resistor burning out, that would explain the high speed fan quiting.
What does it take to restart the compressor?
Mike
Old Jun 24, 2007 | 10:36 AM
rravenn13's Avatar
All I have to do is push the a/c button off and on again and it starts right up.
Old Jun 24, 2007 | 10:39 AM
You might want to confirm my thought but I think you are loosing your resistor pack that control your fan speeds.
Mike
Old Jun 24, 2007 | 09:20 PM
mordor110's Avatar
Hmm mine almost does the same thing. But mine only does it when running the fan on high for long periods of time, and only cuts off for a second, before I even have time to fiddle with the fan speed switch it comes back on, compressor running and all. Kind of figured it was a resistor dying somewhere, or a loose/bad connection on the fan switch? Not happened enough to bother me yet, and the Dallas summer has been mild so far, but I'm sure that will change in July.......
Old Jun 24, 2007 | 09:50 PM
willlane's Avatar
mine does that on fan speed 4...but NEVER on 3 so I just use 3...
what do I need to check?
Old Jun 24, 2007 | 10:00 PM
mordor110's Avatar
Most likely the fan resistor like Mike said. Iexperienced a Toyota several years ago and it did a similar thing, intermittent on high speed fan, or just didn't work,turned out to be the fan resistor. I'm not sure where it is yet on the Disco? I've had other more important things to work on, onmy Disco, so I've not researched where the resistor is yet? Most likely in the dash behind the glove box/center console somewhere?
I'm wondering if the resistor pack is expensive? Or is that a stupid question LOL!
DiscoRom
Dec 10, 2008 10:07 PM
catchmyktm
Jun 5, 2008 10:59 AM
LordOphidian
May 15, 2008 08:32 PM
Prepilot_3ck
Nov 27, 2006 06:33 PM
DiscoGravy
Oct 1, 2005 08:22 PM
