Caliper Bolts
Old Jun 29, 2020 | 04:02 PM
jastutte's Avatar
Default Caliper Bolts
do i need any special tools to take off the bolts that hold the calipers in place?
the truck i'm working on is from the Rust Belt and it shows. i have already stripped two of the caliper bracket retaining bolt heads and have a bolt extractor set arriving tomorrow.
any other tools or tips i might need?
Old Jun 29, 2020 | 04:07 PM
DiscoJax's Avatar
I have used a large 19mmbox end and a sledge hammer. I could use a 12 point impact socket if I needed to but haven't so far. Could also use heat and penetrating oil....
Old Jun 29, 2020 | 04:21 PM
jastutte's Avatar
hmm. we may be talking about different bolts.
the ones i am referencing are the bolts that hold the caliper to the swivel hub. they are 15 mm, rusted to hell and not hex heads.
page 886 of the D2 Workshop manual.
Old Jul 4, 2020 | 01:30 AM
CameraDan's Avatar
I just did my brakes, and I had no issues removing any of the bolts with my socket set and a breaker bar. Just make sure you're using 6 or 12 point sockets as needed, don't mix those up. And if everything is super rusted, penetrating oil and a torch are your friends (but you probably already knew that!). Good luck!
za105
Mar 25, 2016 05:37 PM
Coldmieser
Nov 8, 2015 07:30 PM
FLA Rover
Sep 15, 2013 03:59 PM
br0keit
Apr 9, 2013 10:30 AM
TRIARII
Dec 17, 2012 07:51 AM
