cam fault
Perhaps you are speaking of a CAN fault which is a communication link in the vehicle. In the workshop manual under automatic gearbox you will find a table of all codes from the tranny ECU.
Like :
Like :
P1841
(16)
(16)
* CAN bus fault Maintains current gear in low range, limp
home mode in high range. Shift pressure to
maximum, harsh gear shifts/engagement.
Mil light on M&S lights on
The CAN buss connects some of the computer modules to each other, so a wire could have gotten pulled the wrong way. Pins 16 and 44 on the connector from the transmision ECU, which may be under left hand seat. May be a twisted pair wire. See attached. CAN is controller area network, links main ECU and transmission ECU.
kbarker27
10-13-2023 04:03 PM
Arth111
02-26-2022 06:28 AM
06Range
05-08-2013 09:01 PM
