Came to a stop with 5 codes and not starting
Old Jun 26, 2013 | 12:12 AM
Scott Weiland's Avatar
Default Came to a stop with 5 codes and not starting
So I just left my house on the way to get gas and 5 miles down the road my 01 discovery engine stop working and would not start. It was not running hot, new starter, newer battery and newer alternator. I got it towed home and plug in my code reader and here is what I get:
-P 0150 P 02 Sensor Circuit Malfunction Bank 2 sensor 1
-P 0335 P crankshaft position sensor A circuit malfunction
-P 0560 P system Voltage malfunction
-P 1884 ?
-P 1319 ?
Also the M and S lights are flashings. Anyone have ideas? thanks for your input.
Old Jun 26, 2013 | 12:31 AM
When it cools off, it may restart. The crank position sensor failing would be my suggestion, and since it controls spark timing it could make lots of other codes pop up. You can verify by attaching a spare spark plug to the plug wire, lay on manifold, and check for sparks when cranking.
Old Jun 26, 2013 | 08:45 AM
jafir's Avatar
Actually getting a code for a crank sensor I guess is pretty rare. When it failed on my 2003, I got a code. And I got the flashing M and S lights.
Sometimes some of the codes will pop up because after cranking for a long time the battery voltage starts going down (my opinion of what happens).
Old Jun 26, 2013 | 08:48 AM
Go for a new crank sensor, around $80 at a local parts store, Lucky 8 has a how to video. Also replace both front 02's and you will be set.
Old Jun 26, 2013 | 10:39 AM
clanch's Avatar
Sounds like a crank sensor, but p0560 is for over voltage. I would check your charging system also.
Old Jun 26, 2013 | 12:57 PM
jfall's Avatar
Bet your battery has an internal short.
How old is the battery?
Old Jul 18, 2013 | 02:18 PM
Thanks for all your help guys. Your all helpful and great I changed the crank sensor and both front 02's, since it came to a stop and would not start again (it fixed that problem!).
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
CapeRover
May 3, 2013 04:35 PM
JBEGIN
Mar 18, 2011 08:41 AM
m robin
Freelander
Feb 1, 2009 03:33 PM
