Camping in rain in Disco opinions on covering over sun roof?
Old Nov 14, 2017 | 04:17 PM
redjeep's Avatar
Default Camping in rain in Disco opinions on covering over sun roof?
I live in the Pacific Northwest and I'm planning to take my son camping. It will rain. Looking to sleep in the Disco. I want to have the ability to leave the sun roofs open for venting. I'm trying to come up with a way to keep the rain out. I'd like something better than a tarp. Maybe a flat panel permanently mounted under the roof rack bars? My only idea so far is to make a metal frame about 3' x 7' with a piece of abs or other plastic attached and mounted under my ski racks to act as a rain cover. I do not have a full safari style rack.
Other ideas? Opinions?
Old Nov 14, 2017 | 04:23 PM
alpinacsi's Avatar
What about the vent visors things for the side windows? Will allow you to open the windows a couple inches and not let the rain in.
Old Nov 14, 2017 | 04:24 PM
zuke's Avatar
How about just crank all your windows down about an inch. Always worked for me. With the second row seats out I always have my daughters sleep in the disco when we are in bear country. But I am 6 foot and I can only sleep if I go at an angle. I usually just go in a tent with a 45 at my side.
Old Nov 14, 2017 | 06:23 PM
Alex_M's Avatar
I second just cracking the windows. The rain gutters on these trucks work great. I've driven in heavy rain with the windows down 3" and never got a drop on myself. Same sitting still. Cracked an inch you'll be perfectly fine even if the wind is blowing.
Old Nov 14, 2017 | 10:44 PM
landlover_1's Avatar
A little pricey but this would probably do the trick:
https://www.firstplacesupply.com/flo...iABEgKnxvD_BwE
Or this is a bit cheaper..
https://fast.wistia.net/embed/iframe...r?popover=true
Cheap, cheap, cheap. Personally I'd go with a toilet plunger and a beach umbrella and call it good cuz I'm really cheap.
In all seriousness - you'll probably be fine unless you have one of those leaking sunroofs everyone writes about on this forum.
Have fun!
Old Nov 15, 2017 | 10:39 AM
Richard Gallant's Avatar
I am with everyone else windows down just a hair. If you add a small USB fan and rechargeable battery pack to 1 window you will be good. The one I use hangs on the window, is very quiet and moves enough air to keep air flow going.
I aim the airflow to the outside.
I am just out side of Vancouver BC and that is my preference. But I understand the rain issue.
But if you go sunroof open then I think you have the found easiest solution, I would use a small tarp myself if went that route. That was what I used while trying locate my water leak in to the cabin. Took 2 minutes to put up in the rain and worked well to keep water away from the sunroofs
Old Nov 15, 2017 | 10:56 AM
acg's Avatar
acg
Another suggestion is window deflectors. They allow you to crack open your door windows without getting raindrops into the interior. I have had mine for 5 years and no issue with the mounting.
2000 Land Rover / Range Rover Discovery Series II | Rain Guards - Side Window Deflectors for Cars Trucks SUVs and Minivans | WeatherTech.com
Old Nov 15, 2017 | 05:02 PM
alpinacsi's Avatar
Vent Visor...Window Deflector...these things:
Old Nov 15, 2017 | 07:33 PM
DavC's Avatar
Search nakatenga window vents. The discovery models fit D1, D2, D3, D4 because the rear passenger window widths are exactly the same
Had some, loved them.
dusty1
Jan 21, 2014 11:21 AM
AZDISCOVERY
Aug 21, 2013 12:41 AM
Chris-bob
Off Topic
Sep 8, 2011 01:44 PM
Quophi_99@yahoo.com
May 14, 2008 08:24 PM
Phototone
Apr 12, 2008 01:36 PM
