Can I put a 2000 engine in a 2004?
Old Nov 29, 2010 | 11:42 AM
Alex J's Avatar
Originally Posted by tuck
While your engine may bolt up and work fine, to my knowledge, it is illegal to put an older model engine into a newer vehicle. So before you commit to the swap, check your local laws to be sure.
This is true for CA. You can go the other way and put newer engines in older cars. But older engines in newer cars won't pass the visual check for smog and you can't get your reg tags without a current smog.
Old Nov 29, 2010 | 12:43 PM
buick215's Avatar
Older engines might not be as clean as newer engines but a 2000 4.0 uses less gas than a 2004 4.6. I guess laws sometimes don't make much sense.
Old Nov 29, 2010 | 05:12 PM
They dont care how much fuel they use, its what comes out the tailpipe.
Old Nov 29, 2010 | 05:13 PM
buick215's Avatar
But the more fuel burnt the more pollution comes out of the tailpipe. Besides what does a 2004 have that a 2000 doesn't with regard to emission control systems. i know you didn't write the law spike don't take it personal.
Old Nov 29, 2010 | 05:24 PM
I dont know man, it is what it is.
Yes the 4.0 and the 4.6 are the same engine and in theory they should pollute the same.
I didnt write the law, I dont get it either.
They wont let us have diesels here in the US because they pollute to much but yet they use half the fuel as a gas V8 per mile, makes no sense.
Nothing personal taken or sent, I dont under stand it either.
If you live in a state that does not do emissions testing then you are fine.
Just keep in mind that if your state starts or you move or try and sell the truck to a state that does testing you will have problems.
That being said I would drop in the 4.0 and not worry about it if I were in your shoes.
Old Nov 29, 2010 | 08:07 PM
toad2's Avatar
Doesn't matter anyway. Went to the yard today and it aint a disco, it's a friggin' freelander. But, I finally got a multi page thread going!! By the way, the province of New Brunswick wouldn't have a clue what size engine is in anyones truck.
Old Nov 30, 2010 | 08:54 AM
souljad9's Avatar
All 04's had SAI iirc, and are certified as LEV. If your 4.0 ist SAI, you may need to swap the 4.6 heads onto it.
Old Nov 30, 2010 | 09:14 AM
I disagree, a 4.0 uses the same amount of fuel, for the most part as a 4.6, 4.6 just has a little more power.
Old Nov 30, 2010 | 09:57 AM
souljad9's Avatar
According to fueleconomy.gov
2000 Discovery
Fuel Type:Premium
MPG (city):12
MPG (highway):16
MPG (combined):13
2004 Discovery
Fuel Type :Premium
MPG (city):11
MPG (highway):14
MPG (combined):12
I would say 2mpg highway is more gas. The 4.0 should get you 50 miles further on a tank of gas than a 4.6
Old Dec 13, 2010 | 01:55 PM
Simann's Avatar
So I have a 2003 and have a nice little undiagnosable clatter under load, not at idle.
Anyways, I think I read I can put a 1999-2002 4.6 Range Rover engine in my 2003 right? Pretty much plug and play or are there going to be issues with ECU, Transmission, Connections?
Here is motor in question:
http://www.roverlandparts.com/1999-2...y44kmiles.aspx
KlamathMatt
Feb 22, 2013 09:10 PM
djgraham
Jan 9, 2013 06:50 PM
awoods82
Mar 19, 2012 11:54 AM
L. Villafranco
Jul 30, 2011 09:52 PM
4X4 enthusiast.
Freelander
Mar 23, 2010 09:01 PM
