Can no one test our alternators?
Old Feb 19, 2016 | 03:05 PM
Broken08's Avatar
Default Can no one test our alternators?
Went to three parts stores, three separate machines, but ALL THREE reference an alt that has 4 wires to connect. Two red screw connectors, plus a red and white small connector that none of my three alternators I've used have.
Tried on all three machines, even used a new off the shelf alternator but all fail immediately. I'm pretty sure they aren't all bad, but the machines don't seem to have the right info on our alts.
Anyone gotten a good alternator test?
Old Feb 19, 2016 | 03:33 PM
BS50MGSXR's Avatar
i just put my multi meter across the battery terminals and set the meter to read volts, should be around 14v if the alternator is working and 12v or lower if it is not working while the vehicle is running.
Old Feb 19, 2016 | 04:19 PM
Broken08's Avatar
Sorry I will be more specific. I want to test it before it is installed in the car and I want to know how many amps it puts out
Old Feb 19, 2016 | 04:42 PM
number9's Avatar
You'd have to find somebody knowledgeable enough at one of the stores to have a work-a-round for their testers. Not likely to happen and most folks just buy one close to specs, install untested and have no issues. Option may be to find a local elect shop selling alts who may be able to test prior to purchase.
Paul Grant
Aug 24, 2011 01:16 PM
Paul Grant
Aug 24, 2011 01:09 PM
99landroverdisco
Jun 17, 2009 05:29 PM
soupcan
Dec 4, 2007 01:36 PM
rover1200
Jul 14, 2005 05:49 PM
